On Nexus One?
filrouge
Phone: Nexus One
On Nexus One?
Post by filrouge »
Does it work on Nexus One. Installed it but still have the default keyboard. Thanks
Re: On Nexus One?
of course it works. Just follow the instructions on the FAQ
Go to "Language and keyboard" settings, and check the "Smart Keyboard" (or "Smart Keyboard Pro") box. Then chose "Smart Keyboard (Pro)" in the "Input method" dialog, which is accessible in the menu which appears after a long press in any text input box. There is no "Open" option when you download the application, it's normal!
filrouge
Phone: Nexus One
Re: On Nexus One?
Post by filrouge »
Thanks. Works great
