Hi, I just bought app.... I followd youtube and direction. However, I cannot get this app to work!! After going to Lnagage & Keyboard, There is no androig key board setting or international language setting....
Could someone help me to start this app to work please??
I cannot this app to work
Re: I cannot this app to work
so, what do you see when you go in "Language & keyboard settings" ? You should see a list of keyboards in "Keyboard Settings" submenu. If you don't see Smart Keyboard Pro it means it was not installed; have you checked in the market it is marked as "installed"?
Oh Sorry...Yes I see select language, Smart Keyboard Pro, Smart Keyboard Pro with check mark, and TOuch Input. I was referring to Youtube demonstration...
I pressed Smart Keyboard Pro with check mark until Attention boxk poped up. I pressed ok. I would like to be able to use Japanese language....how do I set my phone to be able to do this....??
Make sure you changed the current input method as in the youtube video (long press in a text box until a popup menu appears, and select "Input Method", then "Smart Keyboard Pro"). You also need to install "Japanese for Smart Keyboard" app, and change the language in the keyboard settings.
