how to get my *.zip file signed
Shorte85
Phone: Droid Incredible
Post by Shorte85 »
For someone who doesn't know what they are doing in words of never done this before. What do I need to do in order for my *.zip file to work on the android phone?
I know that I probably need the *.zip file to be signed or something in order for the phone to recognize it. My question is, what do I need, how do I do it to get the *.zip file signed in order for the smart keyboard to accept the *.zip file that I had created and what not.
Please help me, I am stuck and getting irritated.
Thanks...
Re: how to get my *.zip file signed
No, you need nothing special, just make sure the file names are correct (android file system is case-sensitive), and post your zip here if you don't know what is the problem
Shorte85
Post by Shorte85 »
Here is the zip file I am trying to use, not sure what is going on. What I did was I took one of the skins that were provided on the board and downloaded it and placed it on my phone, along with one that I had edited and zipped back up and placed on my phone. The one that I got off of here worked, however mine wasn't found in the list. So I am not sure what I am doing wrong.
The zipped file I am trying to get showed up on my phone is the one uploaded with this post.
Please tell me what I am doing wrong. I would appreciate it.
FlowerBlue.zip
(65.2 KiB) Downloaded 284 times
OK so the problem is simple: your zip contains a subdirectory "FlowerBlue", but skin.xml (and the rest) must be at the root of the archive!
Shorte85
Post by Shorte85 »
Hm, so instead of zipping the folder FlowerBlue, I have to zip the contents within the folder. Right?
yes (and it works, I've tried)
Shorte85
Post by Shorte85 »
Yeah, thanks. I didn't know that, here I was thinking it had to do with something about signing it. Again, thanks I appreciate your help. :)
Now I'm stuck on creating the images needed, I made another post in a different thread that was already started.
