How to Convert FLV to MP4 on Mac
goonsnoopy
Phone: 2.0
Post by goonsnoopy »
Do you often download videos from the websites like YouTube, Google Video, Yahoo but don’t know how to watching them on your portable players? Let me tell you the reason and solution.
Most videos on the websites are FLV videos because of the small size and high upload speed. But FLV format is not supported by some portable devices such as iPhone, iPod, PSP and so on. What we need to do is to convert FLV to MP4 because mp4 is the most common format supported by popular mobile devices. At this time, a Video converter for Mac is the best solution. This program is an excellent professional FLV to MP4 converter Mac with high converting speed and loss-less quality.
Note: Below tutorial is for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to make FLV to MP4 conversion on Mac in details?
Below is a detailed tutorial about how to make the conversion by Video converter for Mac. You can download the program and install on your computer first, and then try to use it as below steps.
Step1. Load files to the program
Launch this FLV to MP4 converter for Mac. For users' convenience, it allows you to import files by directly dragging into the program.
Step 2. Customize output setting
Before FLV to MP4 conversion, you can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the output setting menu.
Step 3. Output your needed format
If you want to convert FLV to MP4, you should choose MP4 in the "Format" list as your output format.
Step 4. Start making FLV to MP4 conversion on Mac
After making all the preparations, you can start conversion by pressing "Convert" button.
Tips on FLV to MP4 Converter for Mac:
1. Video converter for Mac, provides users a variety of video editing features such as trimming, cropping, video adjustments, adding subtitle and Watermark etc.
2. You can preview the video and capture a screenshot on the main interface before conversion.
Look here and try to convert FLV to MP4 now!!!
Related Articles:
--1. How to Convert Xvid to FLV on Mac at ease.
--2. How to Convert WMV to iPad on Mac.
--3. How to Convert WMV to DV on Mac at ease.
