Sometimes, you may want to play a movie on Quicktime, sometimes you may want to edit a piece of your favorite video on iMovie. But as we know, Quicktime and iMovie just accept limited formats, the main supported format is MOV. So, in these cases, we always need to convert video to MOV format. I believe that this Video Converter for Mac will give you a big assistant. For your convenience, we provide a detailed tutorial about how to convert MPG to MOV.
Note: Below tutorial is for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to make MPG to MOV conversion on Mac?
With the below tutorial, you can download the program and try yo make a conversion step by step.
Step1. Import MPG files into the MPG to MOV Converter
You can import files by the below two methods:
1. Click "Edit" item on the tool bar to import files.
2. Directly drag the selected files into the program.
For your convenience, batch conversion is available.
Step 2. Select output profile
Here you should click "Output Setting" icon and choose MOV in the "Format" list as your output format.
Step 3. Start MPG to MOV conversion on Mac
You just need to press "Convert" button, all the tasks will begin at extremely fast speed and superb quality.
Tips on MPG to MOV Converter for Mac:
1. When you make the conversion on Mac by Video converter for Mac, if you want to edit video, please click “Edit” item or just click the icon shown in below picture1. Then you can apply special features to the output video through trimming, cropping, adding subtitle and watermark.
2. Before MPG to MOV conversion, you can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the "Output Setting" menu.
Related Articles:
How to Convert MPG to FLV Converter
How to convert MOV to MPEG on Mac.
How to convert MPEG on Mac.
How to convert MKV to MPEG on Mac.
How to convert MPG to MOV on Mac
- Phone: x2
- Contact:
Re: How to convert MPG to MOV on Mac
The ideas are strongly pointed out and clearly emphasized. Thanks for sharing your thoughts and ideas on this one.
Home
Home
