Hello!
I have configured Smart Keyboard to use it in Spanish. Using T9 layout, when I press the "MNO" button, the order is "OMN" and when I press "WXYZ" the order is "YWXZ". I don't know if it is a bug or if I can change something in the configuration to solve it.
T9 spanish keyboard
Re: T9 spanish keyboard
Actually it was a trick to suggest "o" and "y" with more priority, but I will go back to a normal order in the next version
Hi. Im considering to buy the application but only if this bug was fixed. It's really annoying. Is it solved in the 3.13.0 version? Thanks.
do this letters get handled by the priority system as well?
It will be fixed in 3.14.0darkblade wrote:Hi. Im considering to buy the application but only if this bug was fixed. It's really annoying. Is it solved in the 3.13.0 version? Thanks.
Hey there. I came here to report this, but I see it's been noted.
It's never a good idea to use any kind of letter priority in a fixed layout that relies on repetitive tapping without prediction, because once people memorize the layout it makes them go nuts if you change it
Any estimates on when the next version will be released? I'm on the verge of buying this keyboard or not, but I can't test how fast I am with portrait typing until this bug is solved.
Also, the ç and Ç characters seem to be missing right? It's in every Spanish keyboard due to the fact that it's used in Catalan, and even though it's not used in Spanish at all, many of us use it to refer to Barça football team, you know xD
If you could add this character to Spanish/Latin layout (probably under the C key), it would be complete.
Thanks in advance.
Thanks in advance.
The next version will be released in the coming days. Meanwhile you can try the latest beta, in which I also added the ç so that you can talk about the Barça
