Upgrading from trial version to full version
newcreation7
- Phone: 6129989442
Loved the trial version, so I purchased the upgrade on my Motorola Droid. I have my email receipt number. What do I do next? Occasionally when I attempt to text, I get a message asking if I want to buy or no thanks. At this point I have purchased the upgrade, so I just need to know what's next? Thanks, outstanding app by the way.
Re: Upgrading from trial version to full version
if you still have the message it means you still use the trial version. You need to change the input method and select "smart keyboard pro", the same way you did to select the trial version (the pro version is not an add-on, it's just another app)
