I finally figured out how to use the T9 keyboard to enter numbers from a word mnemonic when entering an "address" to send a txt to (like when using google txt you send the text to "googl" which is 46645)...not that this is really necessary on a phone running google software but I still wanted that functionality. But I prefer not to keep the T9 keyboard as my default so if you had an option to add the letters from the phone dialing keypad to the arrows keypad then it would be awesome!
Otherwise I really like your product. Much better than the stock keyboard and once I get used to switching from ABC to the other keyboards my data entry speed increased a lot.
Thanks for a great product.
Letters on number keys on "arrows" keypad
gmorganVA
- Phone: Droid X Android 2.2.1 Verizon Wireless
