Keyboard Switch function?
- Phone: Nexus 1
On the stock keyboard, you can hold the 123 key to switch between input methods. Would it be possible to do this on Smart Keyboard as well? I like to use the stock for longer typing, because I seem to have fewer typos with it, but Smart Keyboard for URLs and passwords where the long-press functionality is helpful. Being able to switch between the two quickly, without having to visit the Language and Keyboard settings, would be awesome.
- Phone: Droid 2.01
Re: Keyboard Switch function?
I respectfully disagree with adding this application. Below is my reasoning:
1. ) I doubt Cycril could add this feature to the stock keyboard to jump to the SK. I would think that would require access to the SK code.
2.) Adding a feature to the SK to jump to the stock keyboard (but not vice versa) seems counter to the goal of getting people to use the SK.
3.) I think a better use of time is to improve the SK so you no longer want to use the stock one at all.
Just my opinion......
- Phone: Nexus 1
Respectfully, the stock keyboard already does this. I can long press on 123, and I get a menu asking to either A) change settings or B) choose a new input method, including Smart Keyboard. Cyril wouldn't need to add any code to the built-in keyboard at all.
Even if Smart Keyboard becomes as reliable as the Google keyboard, I'd still like to have this. There may be times that I want to switch to something like a T9 input, or Swype, for example, and I don't want to dig through the menus. Not having this feature right now actually means that I use Smart Keyboard less, because it's more of a hassle to switch back then it is to put up with the inadequacies of the stock version.
I could do this, but I don't understand why you would need to go the Language and Keyboard settings. You just need to long press in the text input box to have this menu, don't you ?
- Phone: Nexus 1
Oh, you're right! Fantastic! Never mind then, thanks Cyril!
