the autotext feature is a great way to prevent common mistakes that i make with the keyboard. in fact it has helped me fix poor auto suggestion words such as te-tea, to te-the.
there is a problem with certain words that it wont work with. it appears that something is overriding the autotext feature. for example:
1. i want to remap hoe-how. with this script active, typing hoe-Joe. i have even added Joe-how, and then typing Joe-Joe. nothing seems to work.
2. i want tha-that's (the default is tha-that). when i enter the scritpt, i get tha-that. the script seems to have no affect.
other words and scripts work fine, such as h-he, s-she.
can you explain why it will not work with certain scripts?
thanks cyril
Custom AutoText Unable to Remap Certain Words
Re: Custom AutoText Unable to Remap Certain Words
Problem understood, it will be fixed in next release
I'm sure that many people want to buy tods womens shoes shoes, but someone may think they are expensive. But you can find many high quality tods mens shoes at very cheap price in online shops. Buying from online shops can save you a lot of money.
