hi
i don't know if that's just a feeling or is smart keyboard getting less and less light? (maybe with all the options added at each new release)
i mean, i don't have that feather light feeling i had when i first installed it.... where it's the most easy to feel is when i type too quickly, the keyboard just freezes for a small second and puts me the number instead of the last key pressed... like it was messing itself up with the multitouch... i have to slow my typing so it doesn't get too messy... and that happens VERY OFTEN.
i'm on a htc desire, not rooted, android 2.2 and not many things installed in the phone ram, to keep it as light as possible.
						smart keyboard getting less "light" and a bit more "laggy"..
Re: smart keyboard getting less "light" and a bit more "lagg
this has nothing to do with the new options, but maybe you are using the smart dictionary option and it starts to be too big
Try to uninstall / reinstall the app and let me know if it's better
