3DKey skin
- Phone: Droid X 2.2
Re: 3DKey skin
I keep going back to this one, it has green words in the suggestion bar, that's the only difference to the Green3D.zip
Re: 3DKey skin
Can you change the color of the long press popup. i.e. Long press "Z" and get "!". I'm using 3dKeyd and really want that to be green also.
Re: 3DKey skin
I don't think that's possible. I don't see anywhere in the skin.xml where there is an option to change that. Perhaps it's Android native. But you can put a request in the "Feature Request" forum, and Cyril might make it an option.
Re: 3DKey skin
Could you make one with the main keys being White with Black font and the alt keys the Blue key color with white font?
Re: 3DKey skin
I'll see what I can do maybe this weekend about getting a more "white" colored key, but by rearranging files using my phone, I've got you this to maybe tide you over until then. Download from dropbox:
http://db.tt/yquzNU0
Re: 3DKey skin
Here's the White keys with blue mod keys, I hope this is what you were looking for:
- 3DWhitewithbluemodMDPI.zip
- For low resolution screens
- (24.37 KiB) Downloaded 946 times
- 3DWhitewithbluemod.zip
- Hi Rez Screens
- (66.46 KiB) Downloaded 1279 times
- 3DWhitewithbluemod.png (76.61 KiB) Viewed 11594 times
Re: 3DKey skin
Here's another green one:
- 3DCrayolaGreen.zip
- (69.21 KiB) Downloaded 1094 times
- 3DCrayolaGreen.png (66.84 KiB) Viewed 11594 times
Re: 3DKey skin
And green with a little less texture, and as with all my skins, unless it's specifically listed, they are only for hdpi screens (hi-rez):
- 3DGreaterGreen.zip
- (82.32 KiB) Downloaded 1064 times
- 3DGreaterGreen.png (64.05 KiB) Viewed 11593 times
Re: 3DKey skin
And a blue version of the above:
- 3DKeyBetterBlue.zip
- (61.57 KiB) Downloaded 1460 times
- 3DKeyBetterBlue.png (65.09 KiB) Viewed 11593 times
Re: 3DKey skin
Turquoise (is that how you spell it?) haha.
- 3DTurboTurquoise.zip
- (56.71 KiB) Downloaded 1358 times
- 3DTurboTurquoise.png (81.64 KiB) Viewed 11630 times
