3DKey skin
yakie996
Phone: htc widfire 2.3.4
Re: 3DKey skin
Post by yakie996 »
yakie996 wrote:
Pino wrote:Black background & suggestion bar
Image Image
maybe stubit question but whats the app you used for you battery persetage??
sorry again but how you have your 3g and receive strength in your notivication bar grey by me is it always green.. =(
Re: 3DKey skin
Here's my first addition to open skins. Thanks to Link for the original 3DKey, and thanks to Pino for changing the background to black, and giving me the awesome green keypress, as well as Stealthychief for his colors and shift, delete, space, enter, and search images. I put this skin together using only my phone (granted all I had to do was edit an xml file and shuffle images around, and rename some files) and it only took about 30 minutes, so be glad to know, I made this skin while I was sitting on the John (or the Lou, depending upon which country you're in). All I have is the hdpi images (I believe the ldpi is just the 3DKeyd3 file updated by Pino). I'm posting this from my phone, so if it doesn't upload the zip file and the screenshots, I'll make another post with dropbox links to the skin and screenshots. I never edited the arrows if you use those in landscape (sorry, they're white).
Re: 3DKey skin
Here's the dropbox link (can some courteous person who knows what they're doing post the zip in this thread?)
http://db.tt/5ywYMSI
that was for the skin zip file, here's the link for the screenshot:
http://db.tt/CUp1wPG
http://db.tt/MCda1rV
Green3D.zip
(95.46 KiB) Downloaded 955 times
Re: 3DKey skin
Here's the same keyboard with green background and green typed word and green other words/symbols (I left the suggested word normal so you can still select the color in SKP options menu).
Here's the zip for the skin;
http://db.tt/GCSBP5K
And here's the screenshot of the skin:
http://db.tt/HJ4shs9
Again, I'm using my phone to edit these skins and to upload on this thread, which is why I'm using dropbox (I don't know how to upload the zip and the screenshot to this thread using only my phone, sorry).
Oh, yeah...I only edited the HDPI pictures (sorry low res phone owners).
Last edited by yhwhsupports on Sat Jul 30, 2011 11:55 pm, edited 2 times in total.
mdlam
Phone: DroidX GB
Re: 3DKey skin
Post by mdlam »
I love the 3dkey3d!!!!
Can you make it with the blue corner buttons you did on the earlier greyish style?
Re: 3DKey skin
mdlam wrote:I love the 3dkey3d!!!!
Here you go, I made two versions: the first has the blue corners (mod keys) with the same green keypress:
http://db.tt/tqQ6FwE
And the second has a blue keypress for the mod keys (while retaining the green keypress for all other keys):
http://db.tt/nxHj50r
I hope you like them :-)
mdlam
Phone: DroidX GB
Re: 3DKey skin
Post by mdlam »
I'm digging the first one ALOT, the blue makes it awesome, do you think you can make the shift key blue as well? The symmetry would make it amazing.
Re: 3DKey skin
I'm not sure, as that's not a mod key (and I really don't know much of what I'm doing) but I'll look into it. I believe the way SKP is written, the shift key has to be a normal key, but again, I'll look into it.
mdlam
Phone: DroidX GB
Re: 3DKey skin
Post by mdlam »
Oh ok if not its fine, I'm still going to use it 24/7.
Re: 3DKey skin
Glad you like it.
