- GlossBlack.png (52.19 KiB) Viewed 253844 times
GlossBlack skin
GlossBlack skin
- GlossBlack.zip
- (37.33 KiB) Downloaded 100604 times
wire-to-wire
- Phone: Samsung Fascinate/ 2.1
Re: GlossBlack skin
The GlossBlack is cool too, I can't decide which one I like better 3D or Gloss. But why choose when you can have both.
- nklenchik
- Phone: Samsung Fascinate - 2.1 Rooted
Re: GlossBlack skin
Definitely using this one, but would you be able to make a version where the grey overlay on the black on the keypad is just a bit darker?
Thanks if you can
Thanks if you can
Re: GlossBlack skin
Let me know if that works for you.nklenchik wrote:Definitely using this one, but would you be able to make a version where the grey overlay on the black on the keypad is just a bit darker?
Thanks if you can
Re: GlossBlack skin
Here is the final version combination of the above two. Got rid of the color shift light, darkened all of the keys and added a little highlight reflections.
- GlossBlack.zip
- (26.98 KiB) Downloaded 15546 times
wraithevolution
- Phone: Nexus One 2.2.1
Re: GlossBlack skin
At Link's permission, I made a version of the Glossy Black keyboard that highlights red when buttons are pushed. Link's keyboard, red altered by myself.
Glossy Black Red
Glossy Black Red
- GlossBlackRed.zip
- (37.34 KiB) Downloaded 15627 times
wraithevolution
Re: GlossBlack skin
This is just another variation of the red highlight keyboard I altered. Of course, orginal credits go to Link for this wonderful keyboard skin.
This is Glossy Black Red Lined
- GlossBlackRedLined.zip
- (37.37 KiB) Downloaded 28568 times
fekish
- Phone: 0035799347957
Re: GlossBlack skin
i suggest you have printscreens of portait mode. Basically myself i care more for portrait mode and very little for landscape...
wire-to-wire
Re: GlossBlack skin
The gloss black red lined looks awesome on my phone. Could you do a blue or android green?
