sometimes suggestions doesn't appear correctly in Russian language. It seems to me that information about keys nearness is not full. I'm ready to help you if you describe me the way I can be helpful
Actually I meant, that suggestions not always appears even for some words existing in the word list. Nevertheless I'm for sure ready provide you with more complete word list if you tell me in which format it should be made.
So how do you know that the word is in the list if you don't see it in the suggestions ?
Can you give me an example (of word, and app where it doesn't work) ?
As for the format, it is very simple, it is just a list of words but ordered by frequency (that's the important thing), and it should contain all word flexions
