Hello!
Would it be possible to create an Unicode input? That new keyboard layout would only need the numerals 1-0 and the letters A-F. If you then enter a unicode value, Smart Keyboard would automatically change it to the character.
For example: Type 01DA and get ǚ.
Would also be nice if it not only supports the BMP, but also the other Planes (16 Bit).
I think this would be nice to be able to type some special characters, not found on any keyboard.
Thanks!
Unicode Input
Re: Unicode Input
That may be possible, but if it's because a language is missing in Smart Keyboard, I will be happy to add it
Re: Unicode Input
Well, the thing is that not everything in Unicode is really worth a keyboard layout.
Some characters are just... well
Even though they may be nice to input sometimes.
(A problem could be that the android font does not support the character, but if you root the phone and have a different font, you could use it).
