T-Mobile G2 .com key bug
The new G2 has a dedicated ".com" hardware key, which produces a rectangle instead of the correct text. This occurs in any text field. Bug?
JonGuerriero
Re: T-Mobile G2 .com key bug
Bumping this because I just upgraded to a G2 and am running into the same issue. I am also running Cyanogen mod. The key should be typing either "www" or ".com". Anybody have a fix?
