What is MKV?
MKV, also known as Matroska, is an open source container format. A MKV file can hold an infinite number of video, audio, and subtitle tracks. Thanks to its added features like support for OGG audio and variable framerate video, MKV has become the standard of multimedia container formats. It is highly flexible for meeting future needs.
Why convert dvd to mkv?
Just want to watch, edit, or share your DVD files easier and more convenient? Converting dvd to mkv then you can free your DVD files from discs so that you can do more with them!
You can store the DVDs to your computer or many other portable devices like iPhone, iPad, iPod, and Apple TV, so you can enjoy DVD movies anytime and anywhere. Or if you just want a better storage and protection of those DVD files, convert them to MKV is also a good choice. By the way, if you are not Mac user, you can go to Windows version.
How to convert dvd to mkv with this DVD Ripper for Mac?
If you want to rip DVDs to MKV, please download dvd ripper for mac first, now we support free downloading for you. After downloaded the DVD Ripper, install and run it on your computer, and then you can follow the guides below.
Step 1: Add files to this dvd to mkv Converter
There are two ways you can add DVD files to this program. Just drag and drop DVD files or click File>Import>Load DVD…/Load DVD Files…
Step 2: Choose the output format and preset the output effect.
To convert dvd to mkv, you should choose "MKV" as the output video format. Click "output settings" icon in the main interface, and then you can choose the output format, select "Common Video" and choose "MOV". Besides, this dvd to mkv Converter for Mac enables you to set the output effect, you can preset video resolution, frame rate, and bit rate for the output file.
Step 3: video editing
Before conversion, you can trim, crop, adjust, subtitle, and watermark the video. Just click "Video editing" icon in the main interface, you can also preview the movies here. After finished the editing, click "Done" to save it.
Step 4: Convert dvd to mkv
Finally, click "Convert" button in the main interface, you can convert dvd to mkv. This DVD Ripper will give you the wonderful output effect.
Tips of this dvd to mkv Converter:
If you want to convert your DVD files to other video formats like MOV, M4A, MP4, WMV, FLV, AVI, 3GP, 3G2, MPEG, etc, this DVD Ripper for Mac can also meet your needs. What' more, you can also convert DVD to many audio formats like M4V, MP3, WAV, AAD, OGG, AIFF, WMA, FLAC, and more.
Just download dvd to mkv converter for Mac here!
Related Articles:
1. How to convert DVD to MOV on Mac?
2. How to convert DVD to MP4 on Mac?
3. How to convert DVD to MPEG on Mac?
