"?!23" on Better Keyboard Skins won't change color
eolsgaard
Phone: HTC Droid Indredible
Post by eolsgaard »
Whenever I use a Better Keyboard skin on Smart Keyboard (let's use the BK iPhone keyboard as an example), I noticed that the "shift" key, "backspace" key, and "enter" key all change properly to white. However, the "?123" key never changes from anything but black. It's not a big deal, but it does throw off the symmetry and is a little awkward aesthetically. When I use the default Smart Keyboard skins, this problem does not exist, of course. Is this because the "?123" key also doubles as a shortcut to SK's settings?
Could it be changed to that the "?123" key automatically changes like the rest of the keys, or if that's not possible, that it can be toggled whether it's black or white? Most skins only use black or white to color the text on keys.
Here's an example of what it looks like:
And here's an example of what it should look like:
Re: "?!23" on Better Keyboard Skins won't change color
That's right I forgot a detail in the skin loader.. I will fix
eolsgaard
Post by eolsgaard »
Thanks!
