Reverts to T9 in portrait mode?
Basically just using this with handcentsms and more often than not, when in portrait mode, SK reverts from normal to T9. I keep going into settings and changing it back but it reverts to T9 when I start up handcent sms.. Why oh whY?
Re: Reverts to T9 in portrait mode?
I would say you do a left swipe gesture by mistake which takes you back to normal keyboard
Just disable this gesture if you don't need it...
Thanks Cyril! I've disabled gestures and I'll check back in tomorrow to let you know if the problem persists!
Update: No bug! Just me not being aware of the features. =) Thanks again Cyril!
