Voice to text / mic on Dolphin Browser search
sharonpta
Phone: HTC Evo (Sprint)
Post by sharonpta »
When using the stock browser and tapping the search "soft key", the "mic" icon appears to the left of the space bar as intended. However when using the search feature in the Dolphin HD Browser, Smart Keyboard Pro sees it as a "url" field and removes the mic icon replacing it with the ".com" icon. In some Android implementations, when using the stock keyboard with the stock browser, when tapping the Search "soft key" for the first time, typically the field is seen as a "url field", when tapping the search soft key again, it is handled as a "Quick Search" and the mic icon should appear. Can that functionality be added to both the stock and Dolphin / any 3rd party browser or at least treat the Dolphin HD browser as you do the stock browser, default being the "Quick Search" field?
Thanks,
Sharon
