Google I/O modified
AndroidGX
Google I/O modified
Post by AndroidGX »
Hello there ! 8-)
I found meyergre's work absolutely amazing about his original Google I/O keyboard (which I thanks very much!).
I decided to do some modifications on it.
I don't kow if you guys will like it but I post just in case :)
Here is the list I modified on the original xml file :
  • <label>#FF1f4176</label> to : FF000000
    <mod-label>#FF1f4176</mod-label> to : FF000000
    <other>#FF778797</other> to : FFa4bbd3
Here is the list I modified on drawable's folder
using Photoshop :
Screenshots :
Key pressed :
  • Image
Normal look :
  • Image
Original Google I/O skin look :
  • Image
GoogleIO_AndroidGX_MDPI.zip
(7.5 KiB) Downloaded 1956 times
