I just created a Crowdin project for Smart Keyboard (here: http://crowdin.net/project/smart-keyboard), which is a very convenient way of maintaining translation of Smart Keyboard settings for every language.
This projet is open so everyone can join and update the translations, however please post in this topic if you are interested in translating a given language, to avoid translation conflicts. At the moment the available localizations are french, italian and korean. I hope to have a translation for every language supported in Smart Keyboard!
Thanks for your contributions
Localization for all languages
Re: Localization for all languages
Great, i translate the german language.
I'll take care of the Spanish version (nickname Blissfull on crowdin)
I've advanced with the spanish translation, only have a few left to do, some specially I'm choosing just the right word (toggle), anyhow, I also had context questions for a few words so please when you can, check the site and answer any pending questions.
Thanks a lot.
Lars.
Thanks a lot.
Lars.
Well I received some days ago context questions which I answered at that time. Do you have other questions? I didn't receive any notification for new questions, or at least I don't know how to see them if there are some
I can do Polish. My login on crowdin: limping
@Lars_G: In PL translation I'm using polish replecement for "mode" because imho when You say e.g. "Toggle T9" You are thinking "Toggle T9 mode" in Polish it fits perfectly but I don't speak Spanish so i don't know will it fit in Your language.
limp ;]
limp ;]
I can do the Hungarian translation. My username at Crowdin is cenzi.
- Phone: HTC Hero Android 2.2
I've just translated almost everything to Russian language (except Slide Popup accents phrases, because I have no idea what does it mean)
Hope I helped to improve the best keyboard ever
Great, I will include this in the next version. Well, "slide popup" is a bit technical, it's a setting to avoid raising your finger when you display the popup keyboard (with accents) after a long press on the key. If you disable this option, you need to raise your finger and then click on the right letter (instead of just sliding the finger).cherkasoff wrote:I've just translated almost everything to Russian language (except Slide Popup accents phrases, because I have no idea what does it mean)![]()
Got it, translated. After I see translated release will it be possible to correct something?cyril wrote: Well, "slide popup" is a bit technical, it's a setting to avoid raising your finger when you display the popup keyboard (with accents) after a long press on the key. If you disable this option, you need to raise your finger and then click on the right letter (instead of just sliding the finger).
