Hi Cyril
Would it possible to disable the language selection key without loosing the ability to switch languages via the swipe feature? It could save some valuable space on the keyboard and prevent one from accidentally hitting the language selection key (which happens to me frequently).
Thanks for considering it!
disable language selection key when using swipe feature
clicious
- Phone: Nexus One
Re: disable language selection key when using swipe feature
Yes I think it would be useful, I will try to add this option in a future version
