And I don't know if I should report this under bugs or here, but here we go. I'd like the left swipe-gesture to be more forgiving. Don't know if different command makes a difference, but I find deleting words with the left swipe to be very hard to do with the thumb. I actually was just about to report that it doesn't work until I noticed I have to use my index finger and swipe COMPLETELY straight. A lot easier to delete words with Swiftkey which has the same gesture.
123 multitouch / swipe-tweak
First I'd like 123+letters to work the same way shift+letters work with multitouch. If I press shift + "v" I get "V", and if I press 123 + "v" I get "v". What I'd like to see is that 123 + "v" gives me ":" (which is the alt-key at least on the swedish keyboard). Now I have to hold "v", or press 123, "v" and then 123 again. Not a big deal but since we have multitouch, why not use it?
Re: 123 multitouch / swipe-tweak
i like this feature too.
just like ics keyboard and perfect keyboard.
holding on 123 +letter will get symbol chars and it will automatically back to alpha layout.
