Just bought the keyboard and think it works good, faster than HTC's keyboard on my Wildfire and better features than anything I've seen.
However, there is one major flaw as I can see, at least on my phone (which is basically a Hero). If I type a word and press space, and then tap on another key really fast, almost at the same time as I let go of the space key, I get no word suggestions. An example:
I type the word "You", press space, let go of the space key and type "ans" and then space, it corrects it to "and" and all is fine. But if I type "You" and press space, and as soon as I let go or the space-key I press "a" and continue typing "ns" to get the word "ans", I get just "ans" and no suggestions at all.
I've been trying to learn how to reproduce this bug and I've found out that if I hold space and press the nextcoming letter, let's say "a" really briefly (just tap it) it won't give me any suggestions, but if I hold "a" just for a little while, 100-200ms perhaps, I will get the suggestions. And, this only happens when I HOLD the space key during pressing the "a"-key. If I let go of it and press the key it won't matter how briefly I tap the key, it still works. Must be something with multitouch with space and the word suggestions not being able to launch somehow.
As I said in the example, it gets that fault if I press the "a"-key (very briefly as I usually press the keys) as soon as I let go of the space-key. Could it be that it takes some time to register that I've let go of the space-key so it basically thinks I'm pressing both space and "a" at the same time, thus making a very brief "a"-press not launch the word suggestion?
I'm not sure if my phone's just slow but I mean it's basically a hero spec-wise so it should work fine. Could someone try to write a word, hold space and tap the next key VERY quickly and see if you get any word suggestions? Could this perhaps be related to the other multitouch-issues people have reported? Is it possible to disable Multitouch on just the space-key so it's impossible for the phone to think I press the space and "a"-key at the same time when typing really fast?
Word suggestions sometimes does not activate
Lidodido
- Phone: HTC Wildfire, Android 2.1
