the vibrate when keys are pressed doesnt work correctly according to long, medium, and short. basically the short doesnt have a vibrate.
also is there a reason you made the delete/shift key tiny? i loved the layout before. is there a way to get the old keyboard back?
vibrate on key
Re: vibrate on key
For the vibrator, I think it depends on the phone, on mine it works fine even for short... but I will put a slider in the settings, it will be better
As for the delete key, I got a lot complaints it was too close to the "M" key, so the only solution is to make it smaller. It's also what is done in HTC Sense and iPhone keyboards, so I expect most people prefer this, but it's painful to make this configurable.. If I get other complaints I will reconsider this
Re: vibrate on key
thanks! youre right it's so much better! and wow no more keyboard crashes and going all nuts on me with crazy deletes! (knock on wood)
