suggestions arent working
Ok so I just installed but it seems that the word suggestions aren't working either that or its the worst Ive ever seen. All I get is basically a copy of what I wrote and nothing else? Is there a setting I need to enable or something?
Re: suggestions arent working
Ok so I figured this out. Apparently you need to install the dictionary, a simple fix. Heres the thing I've used a lot of keyboards and have never had to install a dictionary, also ok. What is not ok is that I searched all over, The Google play page, the website and this forum and didn't find one mention of having to install a dictionary. You know where I found my answer? Another forum, from a thread where someone was asking the same question. Another person installed the app and had the same problem too, figured it was just terrible predictions. Finally someone said install the English dictionary and it will work. Lo and behold it does and the dictionary says must be installed for predictions to work, but the main app page does not.
You would think that if you had to do that it would be something that you would want to put on the Google play page for the app or maybe in the FAQ so when someone goes on the site when they're not getting any predictions it would be easy for them to find out how to fix it.
