Help change suggestion bar color to black
vladeoff
Phone: O1 2.2.2
Post by vladeoff »
Hi! I was a bit confuse changing the color of the suggestion bar to black. I tried the XML file to add like this:
<candidate>
<background>
<color-top>#000</color-top>
<color-bottom>#000</color-bottom>
</background>
</candidate>
I use the GreyhoundR-LND file where I downloaded also from here.. :( please help me.. I can't fix it by myself. :( thanks in advance.
vladeoff
Phone: O1 2.2.2
Re: Help change suggestion bar color to black
Post by vladeoff »
btw.. my phone is LG Optimus One.. hope someone here has the ability to fix my problem in this theme.. :( thanks again.. will visit this thread in a couple of days.. :p
Golyadkin
Phone: HTC Desire CM7.1
Post by Golyadkin »
GreyHoundR-LND.zip
Black suggestion bar
(54.9 KiB) Downloaded 1250 times
The only way I found to change the suggestion bar when making my skins was to add png files for the suggestion bar and divider. I've changed the skin's xml file so that it should now have a black suggestion bar with white and reddish word candidates, obviously you can change the colours of those to your liking by editing the xml.
I've not tested this, I hope it works!
vladeoff
Phone: O1 2.2.2
Post by vladeoff »
Thanks! It was perfect.. and for those who downloaded the file please give credits to him.. thanks mate.. I owe you this theme.. :)
