can't activate
sireag
- Phone: samsung galaxy nexus android4.0
can't activate
I changed my phone from Droid1 to samsung galaxy nexus with android 4.0. When I re-downloaded smart keyboard pro it is selected in the settings, but I can't activate it. When I long press in a text box I get no input choice and the phone just keeps using the Android keyboard even though it is deselected in Settings. Can you help me?
Spongebob290
- Phone: Galaxy S2 ICS
Re: can't activate
Hi matey...I had this problem after resetting my Galaxy S2...after installing the disastrous Ice Crap Sandwich.
the long press doesnt work on the later versions. I accidentally found this. On the standard keyboard skin, there is a settings icon...a little gear wheel....you might have to swipe left or right to enable it. Hold this for a bit and the menu to choose Smart Keyboard comes up.
Bob
Bob
