I love SKP but I have one pet peeve. It seems to want to add punctuation when I have typed any. The worst example is when using T9, I'll hit the GHI and then MNO keys, wanting the word "go" which is the obvious text predication for that key combination but SKP will always give me the word "I'm" instead. Really punctuation should never be given priority unless the punctuation is actually typed. Suggested yes but after the obvious non punctuated word. I have not figured out a workaround for this. What's ironic is that I hated the default Samsung keyboard (I have an Epic 4G Touch) because it would never offer up I'm even if I typed the punctuation.
On my old HTC Hero the HTC T9 keyboard prediction was nearly flawless in my opinion. Too bad I can't "borrow" it for my Samsung.
go=I'm
Re: go=I'm
Anybody?
Re: go=I'm
You could turn off autocorrect, or maybe save the word you desire after typing it to the dictionary... not sure what else to do. If it is a bug with the application, cyril has been absent for a while, so it may not get fixed.
Re: go=I'm
by default "GHI MNO" gives "in", so I guess you have the "smart dictionary" option enabled, and you type "I'm" more often than "go". A workardound is to define a custom AutoText "gm -> go" if you want to force "go" in this situation
