hTC Sense 4.0 Skin v1.1 for HDPI
Re: hTC Sense 4.0 Skin v1.1 for HDPI
also have a look at the pattern below the buttons on the original skin
- Phone: Motorola RaZr.
First of all, great great work!!
There is hardly any diffrence between the skin and the origianl...
secondly, for those who can't get it to work, I am assuming you have (like me) two cards, Internal and External.
I tried, as per the instructions, to put it on the root of the SD card. Nothing.
Then! I just copied the folder 'skins' to the internal card and boom!
OR All you have to do is make a 'skins' folder with the skin's .zip and also extract it for safety reasons...and there you are!
- Phone: I9100 4.0.4
Any reason for me getting the following?
Attached the image.
Using Galaxy s2 at 216DPI.
Attached the image.
- Screenshot_2012-06-29-13-06-17.png (37.68 KiB) Viewed 12816 times
Can anyone make his for other DPI.
LDPI
MDPI
etc?
LDPI
MDPI
etc?
Motorola Triumph Skins also gives the best results in the protection of the phone. I purchased Motorola Triumph Skins which are good in use and available in awesome results.
I wanted to thank you for this great read!!
dose htc sense have Google map?
