Dear Cyril,
I have just e-mailed you the correct layout for armenian keyboard, both the 3-row and 4-row versions, with UTF-16 code tables. Will be grateful if my language is also fixed in the next version of your application.
Thank you.
Armenian Language: Correct Layouts
feleq
- Phone: HTC Sensation; Android Version: 2.3.4
feleq
Re: Armenian Language: Correct Layouts
Dear Cyril,
It would be very nice of you to post a reply in this thread. A "Yes" or "No" will be just enough
Please help to fix the Armenian layout.
http://www.dexilog.com/smartkeyboard/fo ... =2&t=32537
