[Request] Black skin with black bar
Patolucas
Phone: HTC Wildfire S
Post by Patolucas »
Hello,
I do not speak English very well, I'll try to help me images to make myself understood.
I love the skin "black" in this applixation "smart keyboard"
But when you write with this keyboard, a white bar appears to offer us words.
I like to have the same skin but with the black bar.
( As an option, I would like other colors for the words (and arrow) of the bar, et I would like to remove the line separating the words.)
Thank you in advance for your help.
Golyadkin
Phone: HTC Desire CM7.1
Re: [Request] Black skin with black bar
Post by Golyadkin »
I can have a go at this later, it shouldn't be too difficult.
Just a few questions though;
Will a HDPI only version be ok?
What press effect would you like? Maybe a halo effect in the same blue as in your images? Or none at all?
The arrow colour can't be changed though, it'll be the same usual grey colour.
Golyadkin
Post by Golyadkin »
noir.zip
HDPI and MDPI.
(42.56 KiB) Downloaded 1770 times
The candidates colour hex code needs to be changed in advanced settings to #ff005bcc.
Edited, no key press effect.
Patolucas
Post by Patolucas »
No press effect, thanks ;)
Great, thank you
And thank you for this skin, but ... my bar is always white: (
I've done the right thing ( http://www.dexilog.com/smartkeyboard/fo ... f=13&t=612 ) , the skin "noir" appears in the application
Golyadkin
Post by Golyadkin »
OK, I'll change that.
What device have you got?
Patolucas
Post by Patolucas »
HTC Wildfire S :D
Golyadkin
Post by Golyadkin »
Patolucas wrote:HTC Wildfire S :D
So does this skin work ok now?
Patolucas
Post by Patolucas »
Yes, it works!
Thank you very much ;)
Can you change a little detail? :oops:
he small green dot ... can you make it blue?
Golyadkin
Post by Golyadkin »
noir.zip
(42.61 KiB) Downloaded 2008 times
There you go!
Patolucas
Post by Patolucas »
PERFECT :!:
thank you :D
