Xperia S Skin (HDPI only)
Golyadkin
Phone: HTC Desire CM7.1
Post by Golyadkin »
As requested. :)
xperiaS.zip
HDPI only.
(31.14 KiB) Downloaded 4586 times
The candidates colour hex code needs to be changed in advanced settings to #ff000000 for this skin to appear as below.
The keys in this skin are slightly taller than the Xperia S keyboard's to make room for the alt symbols.
schrochem
Re: Xperia S Skin (HDPI only)
Post by schrochem »
Its really nice to see some new skins showing up! Thanks
If I could request another version with a slight tweak that would be great.
The keys seem a bit too grey on my screen.
It the key gradient could be brightened more white it would offer more contrast against the background.
Again this might just be my phone (tbolt).
Thanks again for something a bit new Goly
eddymjj
Phone: SE Arc
Post by eddymjj »
Thank you for your work.
Maybe a little wider keys as its look thin on WVGA
ezeygtr40
Phone: Sony Ericsson X8, GingerDX 2.3.7
Post by ezeygtr40 »
Can u make for mdpi also? Thanx
Sent from my X8 using Tapatalk
melaj88
Post by melaj88 »
Why does the skin come up black? i'm using an LG Optimus Slider with Gingerbread
aroykos
Phone: Samsung Galaxy S Plus Android 2.3.3
Re: Xperia S Skin (HDPI only) - Wider version
Post by aroykos »
Took the liberty of creating a version with wider keys, using the above skin. Enjoy.
xperiaS_wider.zip
I did not create the artwork just used Golyadkin's files and changed size.
(51.85 KiB) Downloaded 1651 times
stevennekens
Post by stevennekens »
To the person who posted the wider version: could you please add a version in which the selection colour of the words in the prediction bar is a more neutral colour, like dark grey, instead of the standard screaming orange colour? thanks in advance!
aroykos
Post by aroykos »
You can change this color in:
Settings > Advanced settings > Candidate color
stevennekens
yeah, I kind of knew that. what I meant is not the colour of the font, but the colour of the background when you press it, the same colour that appears if you select a word from the prediction bar by pressing on it...
