Use the bug tracker!
Multitouch and caps lock doesn't work on Acer liquid and multitouch is the only reason I bought it
Re: Use the bug tracker!
[Message split from original topic]
Can you explain what exactly doesn't work for you with caps lock and multitouch?
As the summer is coming,the weather is hotter and hotter.Every fashion girls want to be cool and shiny in this summer. franklin marshall t-shirts are your best friends. In this hot summer, men should buy franklin marshall hoodies as soon as possible to have a cool summer.
