Ability to hide T9 button on T9 keyboard layout
jazle
Phone: SONER ST17i
Post by jazle »
I currently use Sony Ericsson Xperia Active, however i realize it was too small for my big hand. Thanks to Smart Keyboard for offering T9 layout and an option to resize its button height. It save me a lot from having problem on using this small device. However, I wish there some other option available to make it more comfortable usage:
* I wish there is an option to disable/hide the "T9" button, in my opinion the T9 dictionary functionalities is questionable too.
* I wish there is an option to re-arrange this keyboard layout. However, if this option is not possible in a short period of time:
* I wish when this T9 is hidden, its position could be replaced by "." button
* The "." position could be replaced by "back space" button as current position is not comfortable enough for big hand user for pressing it while it was one of the most frequently used button
* those old backspace position could be replaced by "smiley" button.
* The "Return" button could be visible back to its original position.
Thank you Cyril for making Smart Keyboard, I found it is worth for every penny i've spent for this stuff.. :)
Regards,
-Jaimy Azle.
