does not activate
bogart
- Phone: droid eris. updated 2.1
does not activate
I just bought the paid version and I can't get it to activate or come on. I went into settings and turned it on and still no result. Please help
Re: does not activate
help is in the FAQ:
help is in the FAQ:
How do I enable the keyboard? Go to “Language and keyboard” settings, and check the “Smart Keyboard” (or “Smart Keyboard Pro”) box. Then chose “Smart Keyboard (Pro)” in the “Input method” dialog, which appears after a long press in any text input box.
bogart
Well I did all of that then I did it again. I bought the app mostly cause I wanted the iPhone keyboard lay out and it will not work either. I really want this to work.
Sorry, but you probably did something wrong... What people usually don't get right is the last step: Then long press in any text input area until a popup menu appears, select "Input Method" in this menu, and choose "Smart Keyboard PRO" in the list.
bogart
Oh my I am very sorry! It works great now! My incompetent brain wasn't functioning. Thank you so much!
