Is it possible to change the letter which is selected by the first press when in T9 mode ?
For example, when I press the WXYZ key 'W' is selected. Id like to be able to change this so that 'X' is selected as default instead. Is this possible ?
Thanks.
Change default letter in T9 mode ?
jlgmaxsenal
- Phone: Pulse
Re: Change default letter in T9 mode ?
there is an easy way: add "w -> x" in your custom AutoText, and that will make it!
jlgmaxsenal
- Phone: Pulse
Hi thanks - I have tried adding the following to my User Dictionary :
"w -> x"
that didnt work so I also tried:
w -> x
but the 'W' is still selected as default when I press the WXYZ key in T9 mode !
"w -> x"
w -> x
I tried so it worked... but there is a misunderstanding...
I didn't tell you to add "w -> x" to your user dictionary, but to add a "custom AutoText" shortcut. "w -> x" is just a representation, I mean you need to enter a shortcut where w will be replaced by x
jlgmaxsenal
- Phone: Pulse
Hi, sorry for the confusion !
That works great thanks !
