I have put in place a bug/feature tracking system, so that everyone can see what is going on.
It is mandatory to register to report issues, to avoid spam.
It's here: http://bugs.smartkeyboardpro.com
Don't hesitate to use it!
									Use the bug tracker!
						Re: Use the bug tracker!
Cannot register at bugtracker...
						Code: Select all
APPLICATION ERROR #401
Database query failed. Error received from database was #1142: INSERT command denied to user 'cdeguet'@'10.0.135.11' for table 'mantis_user_table' for the query: INSERT INTO mantis_user_table
( username, email, password, date_created, last_visit,
enabled, access_level, login_count, cookie_string, realname )
VALUES
Please use the "Back" button in your web browser to return to the previous page. There you can correct whatever problems were identified in this error or select another action. You can also click an option from the menu bar to go directly to a new section.
