word prediction
elliamacie
- Phone: htc thunderbolt 2.1
word prediction
I'm finding word prediction is not good. Other keyboards prediction is much better. Ultra keyboards new update the prediction is awesome. But the keyboard still has bugs. If smart keyboards prediction could be fixed would be good. Also lag has set in while typing on internet. The touch doesn't keep up with speed. Spacebar after hitting won't space words run into each other. Typing on this site the lag and mistakes made are more noticed.
Re: word prediction
Can you give precise examples of bad predictions?
About lags, have you tried to disable vibration and check if it makes a difference?
