Keyboard Input Problem With Gameboid
srturner47
Phone: droid 2.1
Post by srturner47 »
When running Gameboid, the letter keys no longer work while playing a game when running this on on the hard keyboard with word suggestions. I assume that this would affect all other emulators in the market similarly. The Dpad on the Droid and other keys like the delete key work just fine. I assume that somehow Smart Keyboard is intercepting the keys first which causes the problem. Is there anyway to fix this?
Re: Keyboard Input Problem With Gameboid
I don't know "Gameboid" but yes, Smart Keyboard intercepts the hard keys when you enable "suggest with hard keys", that's how it works.
There are some issues to fix but it's not that easy
Post by shirley0123 »
High quality designer franklin marshall hoodies are envisioned to be worn for years as well as washed again and again, while the physical appearance remains intact. Next time should you be drawn to buy cheap franklin marshall t-shirts.
