[REQ]Ice Cream SandWich Keyboard?
Re: [REQ]Ice Cream SandWich Keyboard?
Gnaver wrote:So here's the screenshot of your skin on mdpi device. Very thick buttons
Ok, I found the problem : I used twice the same bitmaps, so HDPI and MDPI were identical... :oops:
this ZIP should solve this issue ;)
ICS-SDK.zip
(71.34 KiB) Downloaded 958 times
PS : sorry for the delay, I had to reinstall my computer and I was unable to access this website for a couple of days (not from my phone, nor my tablet, nor any PC at home, strange...)...
4tonmantis
Post by 4tonmantis »
oh snap, youre way ahead of me gnaver!..anyways thats exactly what the skin looks like on my phone, if you could remedy this issue thatd be great :)
4tonmantis
mdpi looks rad! a few things tho, the back & voice key icons are is still a slight bit over sized compared to the actual buttons they're on, also when all caps is on the shift key turns the light gray that the buttons are, unless im mistaken the shift key stays the dark gray/black color on the actual ics keyboard, correct me if im wrong tho...the skin looks great btw :D but alittle downsizing on the back and voice icon would make it perfect
Sure I will resize the keys ;-)
regarding the shift key, I checked in my simulator (that's why I named it -SDK ;-)), we will have to wait until the official release of the system, in a dozen of days...
4tonmantis
sweet thx looking forward to it :)! also about the shift key, people have posted some demo footage of the galaxy nexus showing a decent bit of the keyboard usage and functionality, i just remember the shift key not changing color on caps lock but i could be wrong. ill post link if i can find that video
Re: Re: [REQ]Ice Cream SandWich Keyboard?
owlcitybelanova wrote:Hi please someone can create "ICE CREAM SANDWICH A.K.A 4.0" Keyboard
[img]
please, if the skin fit your expectations, change the title of the first post, so other users will be able to find it as an actual skin, not only a request ;-)
update in a few minutes regarding the pictures sizes;-)
sent from my Galaxy Tab 10.1 using Tapatalk
EDIT :
here it is :
ICS-SDK.zip
(70.88 KiB) Downloaded 1108 times
4tonmantis
the voice and backspace icons are certainly smaller lol maybe alittle too small, only a slight increase in size would be great. id say on a scale of 1-10, 10 being right on size wise, id give it an 8, just a tad larger and itd be perfect!
4tonmantis wrote:the voice and backspace icons are certainly smaller lol maybe alittle too small, only a slight increase in size would be great. id say on a scale of 1-10, 10 being right on size wise, id give it an 8, just a tad larger and itd be perfect!
What about this one ?
ICS-SDK.zip
(70.95 KiB) Downloaded 1369 times
EDIT :
just re-installed the android SDK and launched a virtual device to have a look at the shift key : it's exactly the same as in my skin ;-)
4tonmantis
Awesome! Thx so much for the resize, really diggn the skin now 8-)
Can you make it something like this? also adding link for images (3rd post)
http://forum.xda-developers.com/showthr ... ?t=1241742
