I am using Smart Keyboard Pro with Hebrew charset in my Samsung Galaxy Tab 10.1 - and it works perfectly.
I have just purchased an external keyboard - the Galaxy Tab 10.1 Keyboard Dock and it seems that this external keyboard cannot work with Smart Keyboard Pro, but only with the samsung pre-installed keyboard (Samsung Keypad) which DON'T support Hebrew.
Is there any way to still use the external keyboard with Smart Keyboard Pro?
Thanks..
using external keyboard dock for Samsung Galaxy Tab 10.1
latingate
kika
Re: using external keyboard dock for Samsung Galaxy Tab 10.1
I'm wondering if you have found a solution to your problem - I have the same issue.
