Droid Bionic: Smart Key. does not see skins on SD card
mainspring
- Phone: Droid Bionic 2.3.4
I am not having any luck with the Droid Bionic finding additional downloaded zipped skins on the SD card. When looking at General Settings and "Skins" it only shows the stock skins. I have pulled battery, reinstalled Smart Keyboard,and still no luck. Any ideas would be greatly appreciated!
PhilD
- Phone: Droid X - Gingerbread
Re: Re: Droid Bionic: Smart Key. does not see skins on SD ca
motorola changed the path to the sdcard, the correct path is now /sdcard–ext, just copy your skins folder theremainspring wrote:I am not having any luck with the Droid Bionic finding additional downloaded zipped skins on the SD card. When looking at General Settings and "Skins" it only shows the stock skins. I have pulled battery, reinstalled Smart Keyboard,and still no luck. Any ideas would be greatly appreciated!
mainspring
Re: Droid Bionic: Smart Key. does not see skins on SD card
Please be informed that I am extremely stupid!!! My Bionic is not rooted. Where do I locate the /sdcard-ext path?
