This thread is for some skins that have apparently been somewhat forgotten about, that I have made some changes to, and wanted to share them with everyone else. I hope at least someone likes them. I did not create the skins, just modified them. The first one I believe belongs to Link, and I just changed the keys to green with black press. Every skin (at least that I post) is only for hdpi screens unless it states otherwise.
*******I haven't gotten around to fixing all of them, but look back in a week or so to see the others with black suggestion bars as well. I've labelled the ones that have a black suggestion bar*******
Resurrected Skins [Updated to Black Suggestion Bars]
- Phone: Droid X 2.2
- GlossGreen.zip
- (39.54 KiB) Downloaded 1663 times
- GlossGreen.png (48.34 KiB) Viewed 28212 times
Last edited by yhwhsupports on Sun Aug 07, 2011 10:04 pm, edited 2 times in total.
Re: Resurrected Skins
I think this one was originally done by Link as well (that guy's got some serious skills). I like green if you couldn't tell.
- GreenChromatic.zip
- (59.99 KiB) Downloaded 1815 times
- GreenChromatic.png (66.19 KiB) Viewed 28210 times
I've got red carpet in my room...
- RedChromatic.zip
- (65.15 KiB) Downloaded 1941 times
- RedChromatic.png (66.02 KiB) Viewed 28210 times
Can u make a GlossPink?
This is essentially the exact same skin as Link's original, but I found the top half of the keys too white (like fighting a glare) so I swapped another image for that one, and now I'm happy with it. Again, this is all Link, but I placed a different file in place of the "problem." I didn't change the name, so if you have the original, you might get a bit confused, but they'll both work just fine.
- GlossBlackGreenLined.zip
- (37.28 KiB) Downloaded 2090 times
- GlossBlackGreenLined.png (57.57 KiB) Viewed 28204 times
Gloss Pink
- GlossPink.zip
- Black Suggestion Bar
- (40.77 KiB) Downloaded 1375 times
- GlossPink.zip
- White Suggestion Bar
- (37.33 KiB) Downloaded 1228 times
- GlossPink.png (55.32 KiB) Viewed 28200 times
But that was a lot of pink, so I made this also. What do you think?
- GlossBlackPinkLined.zip
- (40.09 KiB) Downloaded 1432 times
- (37.77 KiB) Downloaded 1277 times
- GlossBlackPinkLined.png (60.88 KiB) Viewed 28200 times
But just in case that wasn't enough pink, I made this. Enjoy.
- GlossPinkMod.zip
- (40.83 KiB) Downloaded 1288 times
- GlossPinkMod.zip
- (37.05 KiB) Downloaded 1204 times
- GlossPinkMod.png (64.21 KiB) Viewed 28193 times
Tonya
Hi I was wondering if you would make the 3 different keyboards in purple too? I love the pink.
anyways it would look awesome with the same shade of purple as Chiclet Purple 1. Could you do that for me? Thanks you
Tonya
Love gloss pink mod. Just hope you can do all 3 in purple too. Same shade of purple as chiclet purple 1
