Samsung Lollipop keyboard style skin
arc
Phone: SM N9002
Post by arc »
A skin inspired by Samsung`s TouchWiz Lollipop Android version keyboard. Its in bright colors, perfectly suitable for new Android 5 (Lollipop) bright interface. Hope you like it :roll:
galaxy_lollipop.zip
(12.55 KiB) Downloaded 1482 times
BTW: cyril in the Create your own skins thread you promised to look for the
Code: Select all
<shift-locked> </shift-locked>
code not loading properly. Unfortunately it still doesn`t. It would be great if you can fix it :oops:
PS. Love your keyboard :P
