Default black skin suggestion bar
Is there any way to alter the suggestion bars background color of the default black skin? Thanks
- Phone: Droid X 2.2
Re: Default black skin suggestion bar
Simply corrupt the file of any keyboard that has a black background (behind the keys) and has the color you want in the suggestion bar (ie. take a skin that has the suggestion bar color and remove/edit the pressed.9.png file to break the patch9 and voila, black keyboard with the respective suggestion bar). Did that by accident when unwashed editing a skin a while back. Hope that helps and you're able to replicate the outcome.
In winter, women all like to wear boots. There are many brands offer boots, but I think tods handbags outlet must be the best among all the brands. Tods also offer luxury tods womens shoes that many women dream to have one.
