Hi...
I´m using Smart Keyboard Pro with my Motorola Milestone...
With Stock Keyboard i can type (on Hardware Keyboard) nouns ( ü, ä, ö) by pressing "Shift - Alt - u - u" for ü, "Shift - Alt - u - a" for ä and so on....
How is it possible to type nouns by using the Hardware Keyboard with Smart Keyboard pro?
or isn´t it possible?
Thanks...
Type Nouns with HW-Keyboard
superloko
- Phone: Motorola Milestone
andres3d
Re: Type Nouns with HW-Keyboard
You have the option physical keyboard enabled?
Greetings!!!
Greetings!!!
superloko
Yes ... i have enabled the option physical Keyboard...
Prediction(thats why i bought smart keyboard) is working and so on... only typing nouns isn´t possible...
Greets
Greets
