New feature: Unicode input
Hello, I added a new feature in the latest beta version, that will be useful, I think.
It's a Unicode panel, which allows to enter directly Unicode code points (in hexa). It's accessible with a long press on 123.
Of course to take advantage of this feature, it can be used to define custom smileys, custom autotexts, etc.
Hint: you can tap the character in the suggestion bar or use enter key to validate a character.
Let me know what you think
Vanav
Re: New feature: Unicode input
Post by Vanav »
Thank you for very important feature!
How to use Unicode panel in latest version?
